[Qgis-user] Re: wktRasterplugin with Qgis trunk on Ubuntu
MaurĂcio de Paulo
mauricio.dev at gmail.com
Tue Jun 14 07:21:25 PDT 2011
Hi Duncan,
I've recently upgraded the plugin to start working with gdal 1.8. This
version does not work with gdal 1.7.
I can try to write a workaround for this, but I don't see a reason as gdal
1.8 is the first version to actually load and show data without bugs.
The qgis 1.7 from ubuntugis stable repository is compiled against gdal 1.8.
I wouldn't advise anyone that want to use postgis raster to use versions
without gdal 1.8 for the reasons mentioned.
I need to investigate why the qgis 1.7 with gdal 1.8 is not working. Could
you send me the error message? I've tested here and it works fine. I've ran
into some issues while testing when trying to view data loaded before the
gdal update.
My tests were made with postgis 2.0 from trunk. What are you using?
Thanks for helping!
Mauricio de Paulo
2011/6/14 Duncan Golicher <dgolicher at gmail.com>
> Hello Mauricio,
> I am using Qgis version 1.8-Trunk built against code revision exported
> GDAL/OGR version 1.6.3
> Maybe, I should go back down a version but I do have version 1.7
> running on my desktop PC. In this case the add a raster layer python
> code exits with errors in line 85,36 50 and 134. I could get raster
> layers from Postgis when using QGIS 1.6, but not load them and QGIS
> 1.6 had a bug that led to crashes when rendering some raster layers.
> Thanks for looking at this,
> Duncan
> 2011/6/14 MaurĂcio de Paulo <mauricio.dev at gmail.com>:
> > Hi Ducan,
> > I don't know what repositories you are using.
> > I've tested on ubuntugis repository with qgis 1.7.
> > You can check what's the version qgis is compiled against by the
> > Help-About-About menu on qgis.
> > There should be a line telling the ogr/gdal version there.
> > Could you give me more information about this issue?
> > Thanks for helping me.
> > Mauricio de Paulo
> > On Tue, Jun 14, 2011 at 9:45 AM, Duncan Golicher <dgolicher at gmail.com>
> > wrote:
> >> Thanks for developing the QGIS raster plugin. I had it running with
> >> QGIS 1.6 but since updating to 1.8 from trunk I cannot get it to work
> >> with Gdal on Ubuntu Lucid.
> >> Message ...
> >> GDAL version incompatible with WktRaster.
> >> Your QGIS found GDAL version 1630
> >> I have the latest version of gdal.1.8 and I have tried removing and
> >> reinstalling all components several times.
> >> Any thoughts on the cause of the problem?
> >> Duncan
> > Mauricio de Paulo
> > Engenheiro Cartografo
> > MapeandoOBrasil
Mauricio de Paulo
MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110614/61bd92da/attachment.html>
