[Qgis-user] Device
Mars Sjoden
aurorageomatics at gmail.com
Tue Jun 14 12:35:08 PDT 2011
If just using QGIS,
With fTools installed run a 'buffer' of roads you are interested in, with
proximity of search.
Then use Select by Location in ftools to Select features within buffer
polygon and remove features from selection with Select by Location which
intersect with road...
should work me thinks,
mars
On Tue, Jun 14, 2011 at 11:14 AM, Sivori Sarti da Silva <
sivori at daer.rs.gov.br> wrote:
Hi folks, sorry my english.
> I got a multiline layer with roads.
> And other point layer that represents bridges over the roads.
> How can I do a search of x numbers of bridges in some roads, if the points
> are not touching the lines, due to gps error (at least I believe that's the
> reason)?
> Thanks.
> *Eng. SÍVORI SARTI DA SILVA
> Especialista Rodoviário-EC/SPR
> DAER - Fone 051 3210-5222
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110614/dae79445/attachment.html>
