[Qgis-user] drawing arrows/ lines at desired angles
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Jun 16 03:49:44 PDT 2011
try the qgsazimuth plugin.
You may want also give a look to
http://www.qrap.org.za/
"Q-Rap: Radio Planning Tool" plugin.
cheers
-- Giovanni --
On Sat, 2011-07-16 at 16:14 +0530, Dr. Satyaprakash wrote:
> Hi,
> I am trying to draw arrows/ lines at specific angles. How to do the
> same in QGIS?
> I have the location of Mobile transmission towers. I also have the
> angles in which the transponders are fixed. I would like to show the
> direction of the transponders at each of the tower location. I am
> attaching a snapshot.
> The data would be something like,
> Long, Lat, Dir1, Dir2, Dir3
> 88.42139816,26.70509683,20,120,280
> Dir1, Dir2 and Dir3 are the angle in degrees from North in which the
> transponders are oriented. Ideally I would like to plot something like
> as in the attached sample, however, even a arrow/ line in those
> directions would do. QGIS should read the file, plot the location
> using Lat and Long and then use the three directions to plot arrows/
> lines.
> Looking forward to your help.
> Rgds,
> Satyaprakash
> Qgis-user mailing list
