[Qgis-user] Re: [Qgis-developer] New Python console idea: Expanding the Python console to handle DSLs for plugins eg CADTools
Barry Rowlingson
b.rowlingson at lancaster.ac.uk
Fri Jun 17 00:27:19 PDT 2011
On Fri, Jun 17, 2011 at 4:36 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Well would that be such a bad thing? The DSLs can return a object from the
> evaluated string so why not let them be mixed. This would mean you can do
> things like:
> mypythonVar = (SQL:Select Sum(column) From Table)
> #Some more python code to assign the value to a QgsFeature
Oh I didnt say it was bad, just tricky! Done right it would be good -
Python in Qgis is getting variable values from C++ all the time.
For example, someone might think they can do:
> foo = 1 + 2 # python
> SQL: select * from table where x=foo
In fact, I'd be quite frustrated if I couldn't do that in a single
console. So to implement this, you've got to have some way of getting
variables from one interpreter into another, so you might end up with:
> SQL: select * from table where x=PYTHON:foo
but now you are parsing everything before it gets to the destination
parser, but that could be ambiguous with the destination language. So
then the console becomes a macro language all of its own...
Barry
