[Qgis-user] Default QGIS project file to open plugins automatically
Andreas Neumann
a.neumann at carto.net
Fri Jun 17 02:28:19 PDT 2011
Hi Markus,
Sorry to hear that version 1.6 does not support the --optionspath yet.
Would it be an option to use QGIS 1.7 (to be released these days)? I am
sure that QGIS 1.7 has the optionspath parameter. If you need help on
customization of QGIS it may be useful to directly ask the folks from
Solothurn (Cedric Möri), the author of the presentation where I sent you
the link.
They probably have many of the same issues that you have, being a QGIS
installation with many clients (50-100) that need customization.
Good luck,
Andreas
On Fri, 17 Jun 2011 11:19:34 +0200, Markus Weidenbach wrote:
> Hi Giovanni and Andreas,
> thanks for your help, but still, for some strange reason only about
> 2/3 of the activated plugins (or extensions, I am running the German
> version and I am not sure about the English term used) remain active
> when I start a new project or when I re-start the previous one.
> Many plugins I activated before and which I wanted to use
> permanently, I had to activate again in the QGIS Extension/Plugins
> Manager Window, such as the 1-Band Raster Colour Table, the QGIS File
> Browser, the Raster Calculator, the Import Project, MMQgis, the OTB
> Plugin and many others.
> In the Extension Manager Window the location of the Plugin Directory
> is indicated as C:\OSGEO4W\apps\qgis\plugins but in fact there are
> only a few *.dll files of all activated plugins. Other locations of
> the python plugins, which remain active, are
> C:\OSGeo4W\apps\qgis\python\plugins.
> And in the directory C:\Users\markus\.qgis\python\plugins you can
> find ALL de-activated python plugins PLUS many activated python
> plugins.
> Strange, but could the paths to the plugin directories be the reason?
> Andreas, I checked version 1.6 and unfortunately there is no startup
> parameter called --optionspath, a very useful feature, that might be
> implemented in future versions.
> Regards,
> Markus
> Am 16.06.2011 12:25, schrieb Giovanni Manghi:
>> Hi Markus,
>> I don't know if I understand correctly your problem, but the
>> installed/activated plugins have nothing to do with qgis projects.
>> When you re-open qgis with a blank project you should see all the
>> plugins you have installed/activated the last time you used the
>> program.
>> cheers
>> -- Giovanni --
>> On Thu, 2011-06-16 at 12:19 +0200, Markus Weidenbach wrote:
>>> Dear List,
>>> is there a way to create sth. like a *.qgis default project file
>>> which
>>> activates automatically all plugins I´d like to have when I start a
>>> new
>>> project (or restart an old one with previously activated plugins)?
>>> So far, I have to open all plugins, such as the QGIS File Browser,
>>> manually, all the time again. It seems that the information of an
>>> activated plugin is not being written in the qgis project file.
>>> This
>>> problem does not concern the official plugins already implemented
>>> into
>>> the latest qgis version, but all plugins downloaded later on.
>>> I am using QGIS 1.6 on Win 7, Prof. 64 bit
>>> All hints are welcome.
>>> Markus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
