[Qgis-user] Printing google aerial photography in the layout of	QGIS
    Matt Boyd
    mattslists at gmail.com
    Fri Jun 17 17:11:29 PDT 2011
I'm not sure that the plugin will allow this, I haven't been able to get it
to work anyway.
If I want to use a GE image I turn off all the layers and decorations in the
window I want to print, then file -> save as image. The image / screenshot
is then generated and automatically saved as a georeferenced image so it can
be loaded and then printed that way, resolution, zoom etc stay the same as
the original window so if you want to zoom in on that image you'll need to
go back to the GE image.
On Sat, Jun 18, 2011 at 6:21 AM, legiopatrianostra
<legio.patria at gmail.com>wrote:
> Good evening everyone,
> There is the possibility to print a layout QGIS (print composer), having
> as a theme google aerial photography, available through the plugin,
> OpenLayers Overview?
> The project is set to the projection: EPSG: 900913 (google mercator).
> I ask this because I tried to print the layout, print everything except the
> image.
> Thank you all for your help.
> Orlando
> *** *Antes de imprimir este E-Mail pense na sua responsabilidade e
> compromisso com o MEIO AMBIENTE!
> Before printing this email, take a moment to reflect on your responsability
> with the Environment!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110618/7d4c3f0a/attachment.html>
