[Qgis-user] Export to new Projektion
Claas Leiner claas.leiner at eschenlaub.de
Mon Jun 20 04:10:34 PDT 2011
Hi, thanks for answer
the parameters are
ETRS89 / UTm32:
+proj=utm +zone=32 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
wgs84
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs +towgs84=0,0,0
DHDN GK3:
+proj=tmerc +lat_0=0 +lon_0=9 +k=1 +x_0=3500000 +y_0=0 +ellps=bessel
+towgs84=582,105,414,1.04,0.35,-3.08,8.3 +units=m +no_defs
 From ETRS89/UTm32 to wgs84 and then to DHDN GK3 the result ist right
In one Step From ETRS89/UTm32 to DHDN GK3 the result ist wrong.
Claas
Am 20.06.2011 12:43, schrieb Paolo Cavallini:
> Il giorno lun, 20/06/2011 alle 12.40 +0200, Claas Leiner ha scritto:
>> When I Export a Shapefile from ETRS89/UTM 32 to DHDN Gauss-Krueger 3 the
>> new Layer is more then 150 m wrong. When In export from ETRS89/UTM 32 to
>> wgs84 und then from wgs84 to DHDN Gauss-Kruger 3 the result ist right.
>> (qgis 1.6 and qgis 1.7).
>> Is there a way to change the projektion fro, ETRS89 to Gk3 in one Step?
> You miss the datum shift (+towgs) parameters.
> All the best.
