[Qgis-user] installing 1.7 standalone Win XP: Couldn't load PyQGIS., Python support will be disabled.
Milo van der Linden milo at dogodigi.net
Thu Jun 23 01:02:32 PDT 2011
Hello Janneke,
I think I remember that qGIS can run without pyQGIS, so you should be
good on "regular" functionality with qGIS.
However, for python support you need a more recent version of python
sip. Instructions for installing that can be found here:
http://www.riverbankcomputing.co.uk/static/Docs/sip4/installation.html
Good luck!
Milo van der Linden
2011/6/23 Janneke Qgis <janneke.qgis at gmail.com>:
> Dear all,
> I've just tried installing the standalone version of Qgis 1.7 on XP, and
> after starting the program I get the following error message:
> Traceback (most recent call last):
>  File "", line 1, in
> RuntimeError: the sip module implements API v5.0 but the qgis.core
> module requires API v8.1
> Python version:
> 2.5.1 (r251:54863, Apr 18 2007, 08:51:08) [MSC v.1310 32 bit (Intel)]
> QGIS version:
> 1.7.0-Wroclaw 'Wroclaw', 63ecdd7
> Python path:
> ['C:/PROGRA~1/QUANTU~2/apps/qgis/./python', 'C:/Documents and
> Settings/Admin/.qgis/python', 'C:/Documents and
> Settings/Admin/.qgis/python/plugins',
> 'C:/PROGRA~1/QUANTU~2/apps/qgis/./python/plugins', 'C:\\Program
> Files\\ArcGIS\\bin', 'C:\\Qgis\\apps\\qgis\\python',
> 'C:\\Qgis\\apps\\Python25\\Lib\\site-packages',
> 'C:\\WINDOWS\\system32\\python25.zip',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\DLLs',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\plat-win',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\lib-tk',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\qgis\\bin',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\win32',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\win32\\lib',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\Pythonwin',
> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\wx-2.8-msw-unicode']
> Is there anything else I should install or set? I've also sent it to the
> developer list yesterday.
> greetings,
> Janneke
> Qgis-user mailing list
