[Qgis-user] installing 1.7 standalone Win XP: Couldn't load	PyQGIS., Python support will be disabled.
    Janneke Qgis
    janneke.qgis at gmail.com
    Thu Jun 23 02:17:52 PDT 2011
Hi Milo,
I've tried the osgeo4w installer on Vista, which works. So I can give
that a try on XP as well. However, I need to be able to work with the
standalone installer, as our internet connection here (Tanzania) is very
unreliable and rather slow, and a lot of our clients don't have an
internet connection.
But you got me thinking about why it would be overruled by an older
version: I'd uninstalled 1.6, but still had a version 1.5 installed.
After uninstalling 1.5 as well there is no problem. I've now also
re-installed 1.6 (standalone installer) and that now seems to work
without problems (at least I can start up without error messages...).
Thanks for your help!
Janneke
On 23/06/2011 11:39, Milo van der Linden wrote:
> Janneke,
> It probably ships with the correct python sip, but perhaps it is not
> on your path or overruled by an older version of sip. Have you tried
> the osgeo4w installer, or did you install from the qGIS standalone
> installer? Perhaps the osgeo4w installation process can help as it
> will also install dependencies on the go
> http://trac.osgeo.org/osgeo4w/
> 2011/6/23 Janneke Qgis<janneke.qgis at gmail.com>:
>> Thanks, Milo, I'll give it a try. I need the python bindings. It looks a bit
>> daunting though, last time I tried building things I got completely stuck.
>> I'm a bit surprised that the standalone installer doesn't come with the
>> corresponding python sip - I hoped it would've worked out of the box. Is it
>> supposed to?
>> greetings,
>> Janneke
>> On 23/06/2011 11:02, Milo van der Linden wrote:
>>> Hello Janneke,
>>> I think I remember that qGIS can run without pyQGIS, so you should be
>>> good on "regular" functionality with qGIS.
>>> However, for python support you need a more recent version of python
>>> sip. Instructions for installing that can be found here:
>>> http://www.riverbankcomputing.co.uk/static/Docs/sip4/installation.html
>>> Good luck!
>>> Milo van der Linden
>>>> Dear all,
>>>> I've just tried installing the standalone version of Qgis 1.7 on XP, and
>>>> after starting the program I get the following error message:
>>>> Traceback (most recent call last):
>>>>   File "", line 1, in
>>>> RuntimeError: the sip module implements API v5.0 but the qgis.core
>>>> module requires API v8.1
>>>> Python version:
>>>> 2.5.1 (r251:54863, Apr 18 2007, 08:51:08) [MSC v.1310 32 bit (Intel)]
>>>> QGIS version:
>>>> 1.7.0-Wroclaw 'Wroclaw', 63ecdd7
>>>> Python path:
>>>> ['C:/PROGRA~1/QUANTU~2/apps/qgis/./python', 'C:/Documents and
>>>> Settings/Admin/.qgis/python', 'C:/Documents and
>>>> Settings/Admin/.qgis/python/plugins',
>>>> 'C:/PROGRA~1/QUANTU~2/apps/qgis/./python/plugins', 'C:\\Program
>>>> Files\\ArcGIS\\bin', 'C:\\Qgis\\apps\\qgis\\python',
>>>> 'C:\\Qgis\\apps\\Python25\\Lib\\site-packages',
>>>> 'C:\\WINDOWS\\system32\\python25.zip',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\DLLs',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\plat-win',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\lib-tk',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\qgis\\bin',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\win32',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\win32\\lib',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\Pythonwin',
>>>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\wx-2.8-msw-unicode']
>>>> Is there anything else I should install or set? I've also sent it to the
>>>> developer list yesterday.
>>>> greetings,
>>>> Janneke
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
