[Qgis-user] Georeferencer 3.1.9 bug (?) and work-around
O
mondifero at gmail.com
Fri Jun 24 15:38:32 PDT 2011
Hi QGIS users,
I contacted the author and he confirmed the problem: you can't georeference
an
image that already has geospatial meta data. The easiest thing to do
(rather
than what I described) is to simply strip off the metadata. For example, if
your raster is "raster.tif", you can use gdal to easily remove the meta-data
and
create a new file "raster_clean.tif" as follows:
gdal_translate -co PROFILE=BASELINE raster.tif raster_clean.tif
Now load "raster_clean.tif" into the Georeferencer, and you should be fine.
I
urged the author to include some kind of warning to users whenever they load
an
image that already has metadata.
Cheers,
M
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110624/ca56fa0a/attachment.html>
