RES: [Qgis-user] exporting joined table to excel
Frederico Mestre
mestre.frederico at gmail.com
Sun Jun 26 14:25:51 PDT 2011
It is a shapefile, but in the dbf was only possible to see the fields in the shapefile, not the joins. I just generated a new shape with the joined fields and only then opened the dbf in excel.
Thanks for the suggestion!
Frederico Mestre
-----Mensagem original-----
De: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Em nome de Alex Mandel
Enviada em: domingo, 26 de Junho de 2011 21:45
Para: qgis-user at lists.osgeo.org
Assunto: Re: [Qgis-user] exporting joined table to excel
On 06/26/2011 01:03 PM, Frederico Mestre wrote:
> Hello,
> How can export a table, which can be opened in excel (such as .csv), when I've got joined tables that I joined using the vector properties window join tool?
> Bye,
> Frederico Mestre
If the layer is a shapefile then the dbf is openable in Excel already, no need to export. If it's in a database like Postgis or Spatialite then both of those have tools to export or dump csv.
Alternately if you Right click on any vector layer loaded and do a Save As... Comma Separated Values is an output option.
Enjoy,
Alex
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
