RES: RES: [Qgis-user] exporting joined table to excel
Frederico Mestre mestre.frederico at gmail.com
Sun Jun 26 16:26:37 PDT 2011
Hi Ramon,
If I understood it right, that's what I did (because, as you said, the join
is virtual). I just created a new shapefile which had the joined fields in
the attributes table.
Then I opened the .dbf file in excel.
Frederico
-----Mensagem original-----
De: qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] Em nome de Ramon Andinach
Enviada em: domingo, 26 de Junho de 2011 23:57
Para: qgis-user
Assunto: Re: RES: [Qgis-user] exporting joined table to excel
I think there might be a step missing.
The new join tool doesn't create a new physical layer, but a virtual one.
So to make it visible outside qgis, you need to save the layer you joined to
first.
I'd save it as some new name, and you can save it directly into CSV if you
wish.
-ramon.
On 27/06/2011, at 05:25 , Frederico Mestre wrote:
> It is a shapefile, but in the dbf was only possible to see the fields in
the shapefile, not the joins. I just generated a new shape with the joined
fields and only then opened the dbf in excel.
> Thanks for the suggestion!
> Frederico Mestre
> [mailto:qgis-user-bounces at lists.osgeo.org] Em nome de Alex Mandel
> Enviada em: domingo, 26 de Junho de 2011 21:45
> Para: qgis-user at lists.osgeo.org
> Assunto: Re: [Qgis-user] exporting joined table to excel
> On 06/26/2011 01:03 PM, Frederico Mestre wrote:
>> Hello,
>> How can export a table, which can be opened in excel (such as .csv), when
I've got joined tables that I joined using the vector properties window join
tool?
>> Bye,
>> Frederico Mestre
> If the layer is a shapefile then the dbf is openable in Excel already, no
need to export. If it's in a database like Postgis or Spatialite then both
of those have tools to export or dump csv.
> Alternately if you Right click on any vector layer loaded and do a Save
As... Comma Separated Values is an output option.
> Enjoy,
> Alex
> Qgis-user mailing list
