[Qgis-user] QGIS 1.7 - Problem with legend in composer
Marco Hugentobler marco.hugentobler at sourcepole.ch
Sun Jun 26 23:49:01 PDT 2011
Hi Daniel
This is a bug. The following workaround helps in the short term (before
1.7.1):
Select the legend, go to the right part of the screen,  item->general options-
>position and size..., set height value (in mm) to something reasonable, click
'set position'.
Regards,
Marco
Am Montag, 27. Juni 2011, 08.29:27 schrieb Daniel.Gnerre at vevey.ch:
> Hi,
> I have installed version 1.7 on Windows, and it is not possible to add
> properly a legend in the map composer. I always get a white band on the
> top and on the botton of the legend.
> Any suggestion ?
> Thanks.
> Daniel
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
