[Qgis-user] Converting gif/jpeg images to shape files
Mick bareman at tpg.com.au
Tue Jun 28 18:19:45 PDT 2011
On Mon, 27 Jun 2011 22:29:56 +0200
Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> What is the purpose of converting these maps to vector files?
>  I doubt that it makes a lot of sense to convert scanned historic maps
> to a vector format (unless it is clearly a clean black and white line
> graphic).
Included in the historic rasters is parts of features, eg canals,
turnpikes, etc, that have been omitted from the OS OpenData set I am
using for base layers.
> You will get all sorts of ugly artefacts and the filesize would
> probably be bigger than the original rasters. Also, you would get
> vectors without attribute data (except maybe color/gray values),
> which is also not ideal.
Artifacts I can fix and attributes I can add, it just takes time. File
size isn't an issue at this stage.
> Probably you just want to geo-reference those scanned maps and use
> them as background layers?
> Andreas
As an Invalid Pensioner I am time-rich - money-poor so the time
involved is not a serious concern. The goal of my project is to produce
a set of map layers depicting the world my ancestors lived in (1600 -
1840) that I can share with other family historians.
The desired results are a set of maps that can be shared as either ESRI
shape files, MapInfo tables or Google Earth overlays.
mick
