[Qgis-user] Re: Projection of Shapefile export
Paolo Cavallini
cavallini at faunalia.it
Fri Mar 18 00:08:41 PDT 2011
Il giorno ven, 18/03/2011 alle 11.25 +0800, custard ha scritto:
> From a quick test with the dev version isn't (r15530) and a set of
> single point shape files in AMGz51, MGAz51 and WGSz51s.
> - the AMGz51 point won't display in MGAz51 or WGSz51s.
> QGIS puts up a window saying "Could not draw ShapeFile because:"
> and not giving a reason.
> The debug information says: "failed with error: failed to load
> datum shift file"
> - the MGAz51 and WGSz51s points won't display in AMGz51 and fail with
> the same set of errors.
Please add this info to the relevant ticket.
Thanks.
http://www.faunalia.it/pc
