Re: [Qgis-user] road graph plugin: no starting point?
Sergey Yakushev
yakushevs at list.ru
Wed May 4 23:23:02 PDT 2011
Hi.
Thu, 05 May 2011 07:53:20 +0200 письмо от Paolo Cavallini <cavallini at faunalia.it>:
> Hi all.
> I keep on getting "Start point not on the road" error. I tried different
What set layer coordinate reference system, project CRS and 'on the fly transformation'?
> topology settings (up to 99, the maximum allowed), to no avail.
Topological tolerance does not affect the binding point.
Topological tolerance is a distance between two nodes layer as one node a graph.
You need to set topology tolerance if you see message "Can't find path", but not "Start point no on the road".
> Any hint?
> Thanks.
> Paolo Cavallini: http://www.faunalia.it/pc
> Qgis-user mailing list
С уважением Якушев Сергей yakushevs at list.ru
