[Qgis-user] Re: Remove red vertex markers from a line layer
maning sambale
emmanuel.sambale at gmail.com
Fri May 6 16:42:58 PDT 2011
The red x-shaped vertex markers are visible if your line vector is in
edit mode. Disabling the edit mode `select layer > right-click >
toggle editing`, will remove the markers.
When you closed and reloaded the QGIS session, the default setting of
vector is not in edit mode. This is the reason why the markers
disappeared
On Sat, May 7, 2011 at 1:54 AM, mondo <mondifero at gmail.com> wrote:
> After saving the project, exiting, and reopening, the vertex points
> disappeared!
> Now, I have *new* issues. ;-)
> M
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Remove-red-vertex-markers-from-a-line-layer-tp6338200p6338379.html
> Sent from the qgis-user mailing list archive at Nabble.com.
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
