[Qgis-user] Transparency settings in qml file ignored by rasters?
Agustin Lobo
alobolistas at gmail.com
Mon May 9 07:23:43 PDT 2011
Thanks, Alexander. Bad news, as it seems this is not
fixed for 1.7
I have hundreds of images from a miniUAV, and all of them
are rotated according to a tfw file. QGIS positions the image within
a rectangle of 0, so I need to set 0,0,0 to transparent, otherwise
most of the area is overlapped by black.
Doing this manually for each image is tedious...
Cheers,
Agus
2011/5/9 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Agustin,
> this is a bug. See http://trac.osgeo.org/qgis/ticket/3723
> and probably http://trac.osgeo.org/qgis/ticket/3733
> 2011/5/9 Agustin Lobo <alobolistas at gmail.com>:
>> Hi!
>> I set transparency in Properties/Transparency/Transparent pixel list as
>> 0,0,0 100%
>> (i.e, 100% transparent if 0 in all 3 bands)
>> and save the style to a qml file that gets the following lines close to the end:
>> <threeValuePixelList>
>> <pixelListEntry red="0.000000" blue="0.000000" green="0.000000"
>> percentTransparent="100"/>
>> </threeValuePixelList>
>> Nevertheless, when I open another raster and apply this style, the
>> transparency is not modified.
>> Is this a bug or am I doing something wrong?
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexander Bruy
