[Qgis-user] ugly results with new symbology: how to improve them?
Mayeul Kauffmann
mayeul.kauffmann at free.fr
Tue May 10 10:46:46 PDT 2011
Hi Paolo,
I would just make everything round (cap and join) but then maybe
problem with the offset.
Then, if not enough:
You can solve this by taking a simple yellow line instead of two:
You need:
-one very wide gray band (below)
-one slightly smaller yellow band (above it)
-one slightly smaller grey band
-the dashed white band (on the top)
You also need symbol levels ON on because you have several roads.
Your qml looks almost perfect by me (see attachment), so if the above s
does not work, I can help more but need a sample file (your scale is
strange: "30 000 gradi"???)
Hope it helps,
Mayeul
Le mardi 10 mai 2011 à 18:20 +0200, Paolo Cavallini a écrit :
> Hi all.
> I have defined a line decoration (see style below).
> For straight lines it looks nice, but in normal situations it is ugly:
> https://int.faunalia.it/~paolo/strade.png
> Anyone knows how to improve it?
> All the best.
> <!DOCTYPE qgis PUBLIC 'http://mrcc.com/qgis.dtd' 'SYSTEM'>
> <qgis version="1.8.0-Trunk" minimumScale="0" maximumScale="1e+08"
> hasScaleBasedVisibilityFlag="0">
> <transparencyLevelInt>255</transparencyLevelInt>
> <renderer-v2 symbollevels="0" type="singleSymbol">
> <symbols>
> <symbol outputUnit="MM" alpha="1" type="line" name="0">
> <layer pass="0" class="SimpleLine" locked="0">
> <prop k="capstyle" v="square"/>
> <prop k="color" v="166,166,166,255"/>
> <prop k="customdash" v="5;2"/>
> <prop k="joinstyle" v="bevel"/>
> <prop k="offset" v="0"/>
> <prop k="penstyle" v="solid"/>
> <prop k="use_custom_dash" v="0"/>
> <prop k="width" v="6.26"/>
> </layer>
> <prop k="color" v="255,255,255,255"/>
> <prop k="penstyle" v="dash"/>
> <prop k="width" v="0.26"/>
> </layer>
> <prop k="color" v="255,255,0,255"/>
> <prop k="offset" v="2"/>
> </layer>
> <prop k="capstyle" v="round"/>
> <prop k="offset" v="-2"/>
> </layer>
> </symbol>
> </symbols>
> <rotation field=""/>
> <sizescale field=""/>
> </renderer-v2>
> <customproperties/>
> <displayfield>FNODE_</displayfield>
> <label>0</label>
> <labelattributes>
> <label fieldname="" text="Etichetta"/>
> <family fieldname="" name="Sans"/>
> <size fieldname="" units="pt" value="12"/>
> <bold fieldname="" on="0"/>
> <italic fieldname="" on="0"/>
> <underline fieldname="" on="0"/>
> <strikeout fieldname="" on="0"/>
> <color fieldname="" red="0" blue="0" green="0"/>
> <x fieldname=""/>
> <y fieldname=""/>
> <offset x="0" y="0" units="pt" yfieldname="" xfieldname=""/>
> <angle fieldname="" value="0" auto="0"/>
> <alignment fieldname="" value="center"/>
> <buffercolor fieldname="" red="255" blue="255" green="255"/>
> <buffersize fieldname="" units="pt" value="1"/>
> <bufferenabled fieldname="" on=""/>
> <multilineenabled fieldname="" on=""/>
> <selectedonly on=""/>
> </labelattributes>
> <edittypes>
> <edittype type="0" name="CODICE"/>
> <edittype type="0" name="CODIFICA"/>
> <edittype type="0" name="FNODE_"/>
> <edittype type="0" name="LENGTH"/>
> <edittype type="0" name="LPOLY_"/>
> <edittype type="0" name="NOME"/>
> <edittype type="0" name="RPOLY_"/>
> <edittype type="0" name="STATALI_"/>
> <edittype type="0" name="STATALI_ID"/>
> <edittype type="0" name="TIPO"/>
> <edittype type="0" name="TNODE_"/>
> </edittypes>
> <editform></editform>
> <editforminit></editforminit>
> <annotationform></annotationform>
> <attributeactions/>
> <overlay display="false" type="diagram">
> <renderer item_interpretation="linear">
> <diagramitem size="0" value="0"/>
> </renderer>
> <factory sizeUnits="MM" type="Pie">
> <wellknownname>Pie</wellknownname>
> <classificationfield>0</classificationfield>
> </factory>
> <scalingAttribute>0</scalingAttribute>
> </overlay>
> </qgis>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110510/7d1f570b/attachment.png>
