[Qgis-user] RE: is the openlayers plugin not working?
Matt C
mattwigway at gmail.com
Tue May 10 13:46:32 PDT 2011
Yes, setting the projection to Google Mercator (EPSG:900913) is very
important (you can use the "Enable 'on the fly' CRS transformation" box
to reproject your data, assuming the projection for your data is set
correctly). This error looks like a QT problem, though. Do you have
qt-python installed?
-Matt
On 05/10/2011 03:19 AM, Michael Spencer wrote:
> I find it quite temperamental (v1.6), but generally only if I have
> data already loaded that is in a different projection. Starting a
> project using google mercator seems to be fine. Although often after
> adding the data I have to drag the map about before it refreshes and
> then it zooms out to the whole world.
> Michael
> > Message: 2
> > Date: Tue, 10 May 2011 08:50:50 +0100
> > From: M.E.Dodd <m.e.dodd at open.ac.uk>
> > Subject: [Qgis-user] is the openlayers plugin not working?
> > To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> > Message-ID:
> > <4E7B5FE52E3BEA48AD9AB3AD11BA17A37CD09146DE at KIELDERCMS1.open.ac.uk>
> > Content-Type: text/plain; charset="us-ascii"
> > Noticed openlayers plugin stopped working some time ago but even
> after reinstalling it still does not work in qgis1.6 or 1.7. Had used
> it quite happily with previous versions of qgis and indeed these versions.
> > An error has occured while executing Python code:
> > Traceback (most recent call last):
> > File "C:/Documents and
> Settings/med4/.qgis/python/plugins\openlayers\openlayers_plugin.py",
> line 95, in setVisible
> > self.__initGui()
> line 82, in __initGui
> > self.__setDocWidget()
> line 78, in __setDocWidget
> > self.__oloWidget = OpenLayersOverviewWidget(self.__iface,
> self.__dockwidget, self.__olLayerTypeRegistry)
> Settings/med4/.qgis/python/plugins\openlayers\openlayers_ovwidget.py",
> line 82, in __init__
> > self.__init()
> line 91, in __init
> > proxy = getProxy()
> Settings/med4/.qgis/python/plugins\openlayers\tools_network.py", line
> 34, in getProxy
> > elif proxyType in ["4","HttpCachingProxy"] and QT_VERSION >=
> 0X040400: proxy.setType(QtNetwork.QNetworkProxy.HttpCachingProxy)
> > NameError: global name 'QT_VERSION' is not defined
> > Python version:
> > 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
> > QGIS version:
> > 1.7.0-Trunk Trunk, 15229
> > Python path: ['C:/OSGeo4W/apps/qgis-dev/./python', 'C:/Documents and
> Settings/med4/.qgis/python', 'C:/Documents and
> Settings/med4/.qgis/python/plugins',
> 'C:/OSGeo4W/apps/qgis-dev/./python/plugins',
> 'C:\\OSGeo4W\\bin\\python25.zip', 'C:\\OSGeo4W\\apps\\Python25\\DLLs',
> 'C:\\OSGeo4W\\apps\\Python25\\lib',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\plat-win',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\lib-tk',
> 'C:\\OSGeo4W\\apps\\qgis-dev\\bin', 'C:\\OSGeo4W\\apps\\Python25',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\win32',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\win32\\lib',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\Pythonwin',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\wx-2.8-msw-unicode',
> 'C:\\Documents and
> Settings\\med4\\.qgis\\python\\plugins\\fTools\\tools', 'C:\\Documents
> and Settings\\med4\\.qgis\\python\\plugins\\mmqgis/forms']
> > The Open University is incorporated by Royal Charter (RC 000391), an
> exempt charity in England & Wales and a charity registered in Scotland
> (SC 038302).
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL:
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20110510/597de9bf/attachment-0001.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110510/e2c6fa7b/attachment.html>
