[Qgis-user] ugly results with new symbology: how to improve them?
Mayeul Kauffmann
mayeul.kauffmann at free.fr
Wed May 11 12:24:43 PDT 2011
See below .qml file which gives a more pleasant result.
For those who might not know how to use this: copy-paste the following
in an empty plain text file and save it as mystyle.qml
Then in layer properties, click on button to open a style.
Should work with 1.7.0 as well.
Mayeul
<!DOCTYPE qgis PUBLIC 'http://mrcc.com/qgis.dtd' 'SYSTEM'>
<qgis version="1.8.0-Trunk" minimumScale="0" maximumScale="1e+08"
hasScaleBasedVisibilityFlag="0">
<transparencyLevelInt>255</transparencyLevelInt>
<renderer-v2 symbollevels="1" type="singleSymbol">
<symbols>
<symbol outputUnit="MM" alpha="1" type="line" name="0">
<layer pass="0" class="SimpleLine" locked="0">
<prop k="capstyle" v="round"/>
<prop k="color" v="166,166,166,255"/>
<prop k="customdash" v="5;2"/>
<prop k="joinstyle" v="round"/>
<prop k="offset" v="0"/>
<prop k="penstyle" v="solid"/>
<prop k="use_custom_dash" v="0"/>
<prop k="width" v="6.26"/>
</layer>
<layer pass="1" class="SimpleLine" locked="0">
<prop k="color" v="255,255,0,255"/>
<prop k="width" v="4.8"/>
</layer>
<layer pass="2" class="SimpleLine" locked="0">
<prop k="color" v="160,160,160,255"/>
<prop k="width" v="4.26"/>
</layer>
<layer pass="3" class="SimpleLine" locked="0">
<prop k="color" v="255,255,255,255"/>
<prop k="penstyle" v="dash"/>
<prop k="width" v="0.26"/>
</layer>
</symbol>
</symbols>
<rotation field=""/>
<sizescale field=""/>
</renderer-v2>
<customproperties/>
<displayfield>FNODE_</displayfield>
<label>0</label>
<labelattributes>
<label fieldname="" text="Etichetta"/>
<family fieldname="" name="Sans"/>
<size fieldname="" units="pt" value="12"/>
<bold fieldname="" on="0"/>
<italic fieldname="" on="0"/>
<underline fieldname="" on="0"/>
<strikeout fieldname="" on="0"/>
<color fieldname="" red="0" blue="0" green="0"/>
<x fieldname=""/>
<y fieldname=""/>
<offset x="0" y="0" units="pt" yfieldname="" xfieldname=""/>
<angle fieldname="" value="0" auto="0"/>
<alignment fieldname="" value="center"/>
<buffercolor fieldname="" red="255" blue="255" green="255"/>
<buffersize fieldname="" units="pt" value="1"/>
<bufferenabled fieldname="" on=""/>
<multilineenabled fieldname="" on=""/>
<selectedonly on=""/>
</labelattributes>
<edittypes>
<edittype type="0" name="CODICE"/>
<edittype type="0" name="CODIFICA"/>
<edittype type="0" name="FNODE_"/>
<edittype type="0" name="LENGTH"/>
<edittype type="0" name="LPOLY_"/>
<edittype type="0" name="NOME"/>
<edittype type="0" name="RPOLY_"/>
<edittype type="0" name="STATALI_"/>
<edittype type="0" name="STATALI_ID"/>
<edittype type="0" name="TIPO"/>
<edittype type="0" name="TNODE_"/>
</edittypes>
<editform></editform>
<editforminit></editforminit>
<annotationform></annotationform>
<attributeactions/>
</qgis>
Le mercredi 11 mai 2011 à 10:16 +0200, Paolo Cavallini a écrit :
> Il 10/05/2011 19:46, Mayeul Kauffmann ha scritto:
> > Hi Paolo,
> > I would just make everything round (cap and join) but then maybe
> > problem with the offset.
> Yes, I think the offset is the culprit here.
> > You also need symbol levels ON on because you have several roads.
> I think this is the point, but I do not quite understand how it works.
> > Your qml looks almost perfect by me (see attachment), so if the above s
> > does not work, I can help more but need a sample file (your scale is
> > strange: "30 000 gradi"???)
> I did not care about projection, it was just a quick snapshot.
> All
