[Qgis-user] Join attributes in 1.7
Giovanni Manghi
giovanni.manghi at gmail.com
Wed May 11 16:53:17 PDT 2011
On Wed, 2011-05-11 at 17:43 -0600, Kurt Menke wrote:
> Hello,
> I'm running 1.7 and the tool that used to be in fTools for joining
> attributes is no longer there (Vector menu --> Data Management Tools
> --> Join attributes). There is now only join attributes by location.
> I know that by going to layer properties in 1.7 there is a Joins tab.
> However, the joins tab is only set up to join attributes from another
> layer, not a standalone table. How can I perform a join between a
> shapefile and a csv in 1.7?
you can add geometryless tables (csv,dbf) in a project by using the "add
vector layer" dialog.
cheers
-- Giovanni --
