[Qgis-user] Problem with EPSG
Hugo hfpmartins at gmail.com
Thu May 12 02:22:06 PDT 2011
Hello,
Thanks for the feedback. Everything is working ok now though i'm not sure
why. Today, just after turning on my computer, the epsg reference systems
were all there. So, restarting the computer solved the problem. I just have
no clue about what happened, but the most important is that it is working.
Cheers,
Hugo
On Thu, May 12, 2011 at 5:17 AM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
> Hi Hugo
> This usually happens if you have several conflicting versions of the qgis
> libraries (libqgis_gui.so, libqgis_core.so etc.). Removing the old ones
> helps
> in most cases.
> Regards,
> Marco
> Am Mittwoch, 11. Mai 2011, 23.32:10 schrieb Hugo:
> > Hello all,
> > Is there anything wrong with using gdal 1.8 with qgis? I'm asking this
> > because i've updated gdal from 1.7 to 1.8 today and when i open a project
> > and try to set the base map's SRS there are no SRS (geographic and
> > projected) at all. When using gdal through shell there are no problems
> when
> > defining EPSG parameters. I'm using Ubuntu 10.10 64 bits. Any hint on how
> > to solve this??
> > Thanks in advance.
> > Best regards,
> > Hugo
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-user mailing list
Hugo Martins
LabNT - ISEGI UNL
Campus de Campolide
1070-312 Lisboa
N 38°43'56.84", W 9°9'35.74"
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110512/178e9e22/attachment.html>
