[Qgis-user] terrain profile tool and geotiff
benoit-3 at bc-consult.com
Fri May 13 00:37:10 PDT 2011
Hi Eelke,
On Fri, 13 May 2011 09:23:10 +0200, Eelke Folmer <e.o.folmer at gmail.com>
wrote:
> Thanks Mayeul,
> I tried the spectral profile plugin also. It gives the values if
> multiple (max 5) at a point but not along a transect. The Profile
> Tool
> makes a profile along a transect for max 3 one-band raster layers.
> I guess I will need to split the bands; any hints?
> Regards,
> Eelke
Have a look at the "translate" option of the Raster menu.
Or, perhaps quicker, use GDAL commands from a "command" prompt:
-> gdal_translate your_input_3-band_raster_filename
Output_filename_band1.tif -b1
Output_filename_band2.tif -b2
Output_filename_band3.tif -b3
HTH
Benoit
> Op 5/13/2011 12:10 AM, Mayeul Kauffmann schreef:
>> Hi, there are TWO profile python plugins, maybe try the other plugin
>> first...
>> (Not sure this helps...)
>> Mayeul
>> Le jeudi 12 mai 2011 à 12:10 +0200, Eelke Folmer a écrit :
>>> Hi,
>>> I would like to obtain profiles from various bands in a geotiff.
>>> The
>>> terrain profile tool needs a one band raster layer. Is there a
>>> trick to
>>> do this or should I split the geotiff into separate bands? If so,
>>> how
>>> would I go about that?
>>> Thanks in advance,
>>> Eelke
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
