[Qgis-user] QGIS (map)Server in Ubuntu 11.04
    Saber Razmjooei
    razmjooeis at faunalia.co.uk
    Mon May 16 09:20:59 PDT 2011
Marco
Did you upgrade from 10.10?
I have got one upgraded from 10.10 which works fine. But I tried to
install it fresh and didn't work. I will look into the libraries and
server.
Cheers
Saber
On Mon, 2011-05-16 at 11:38 +0200, Marco Hugentobler wrote:
> Hi Saber
> I'm using QGIS server on ubuntu 11.04 here and I don't notice any major
> changes after  updating from 10.10.
> Could you check if the server is linked to the right qgis libs
> (libqgis_core.so, libqgis_gui.so)?  Also, make sure the fcgi configuration is
> still ok.
> Regards,
> Marco
> Am Montag, 16. Mai 2011, 11.23:14 schrieb Saber Razmjooei:
> > Hi all
> > I am trying to create a wms using qgis-mapserver in Ubuntu 11.04
> > (64bit). I have followed the exact same procedure I did in 10.10 and
> > 10.04.
> > But when I try to add the wms to QGIS, it comes up with Coordinate
> > Reference System (0 available).
> > Any help will be highly appreciated.
> > Cheers
> > Saber
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
