[Qgis-user] Dimension lines plugin
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Tue May 17 13:05:29 PDT 2011
Hi
I started working on a dimension lines plugin:
Select two points, then choose the length of the help lines and a start
and/or endoffset. The startoffset is the distance between the start of
the help lines (or the main/dimension line if the length of the help
lines is 0). The endoffset is used for the displacement of the main line
(if there are some help lines). The offsets and the length of the help
lines are defined in map units. An example can be found here [1].
The lines are stored in two layers in a spatialite database. You can use
a layer_id (an integer value) to arrange them a bit.
There are two simple styles in the plugin directory. The default one:
black lines, main line with arrows and the length of the line is written
on top of the line. The red one: ditto in red.
Drawbacks:
- I guess it won't work with on-the-fly transformation enabled.
- Everything is static. Once you created the lines the won't move if you
change the points/vertex they are assigned to.
The plugin can be found here [2].
[1]: http://www.catais.org/qgis/dimensioning/bemassung.pdf
[2]: http://www.catais.org/qgis/plugins.xml
best regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter amtliche Vermessung
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler at bd.so.ch
http://www.so.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110517/d6662f29/attachment.html>
