[Qgis-user] Re: Problem with tiff (cannot open tiff in Ubuntu 11.04)
Hugo hfpmartins at gmail.com
Tue May 17 13:37:19 PDT 2011
Thanks for pointing this out Mayeu! Let's wait, sure they're upon it.
Meanwhile i have been using gdal to convert from tif to other formats.. so
the work is flowing still :)
Cheers,
Hugo
On Tue, May 17, 2011 at 9:02 PM, Mayeul Kauffmann
<mayeul.kauffmann at free.fr>wrote:
> Hi,
> I mentioned that Ubuntu users cannot open tiffs anymore, on the dev
> mailing list 2 days ago [1].
> Let's hope someone there knows how to solve this!
> Mayeul
> [1] see:
> http://osgeo-org.1803224.n2.nabble.com/gdal-1-8-0-no-tiff-support-anymore-in-Ubuntu-11-04-Natty-tc6365327.html
> Le mardi 17 mai 2011 à 15:13 +0100, Hugo a écrit :
> > Hi all,
> > Thanks for your comments. Edward, thanks for you directions but i
> > really need to solve this issue and moreover i really enjoy
> > QGIS/GRASS, and so, i want to keep up with it. The problem now is that
> > i have several projects saved that no longer work with raster files
> > (it really doesn't matter what size they have). When each project
> > starts loading, i can see all the vectorial files being loaded
> > correctly. But as soon as it gets to load any type of raster file QGIS
> > just crashes ans shuts down.
> > Launching QGIS from the terminal has give me the clue to what is
> > wrong: the problem is with my libtiff version. I can see that i have
> > libtiff 4.0 installed but QGIS is looking for libtiff3 (exactly what
> > Giovanni has pointed out).
> > Here is the terminal output:
> > Error:
> >     GDAL Error 1: WARNING ! libtiff version mismatch : You're linking
> > against libtiff 3.X but GDAL has been compiled against libtiff >=
> > 4.0.0
> > So my question is how can i fix this?
> > Kind regards,
> > Hugo
> > On Tue, May 17, 2011 at 1:38 PM, Giovanni Manghi
> > <giovanni.manghi at gmail.com> wrote:
> >         On Tue, 2011-05-17 at 12:45 +0100, Hugo wrote:
> >         > Just to give software context i'm on Ubuntu 10.10 64 bits,
> >         using Qgis
> >         > 1.6 and GDAL 1.7.
> >         Hi Hugo,
> >         here with Ubuntu 10.04 32bit and the ubuntugis repository
> >         (qgis 1.6) no
> >         problems.
> >         I added a bunch of overviews before opening the raster file,
> >         in any case
> >         no crashes.
> >         On the other hand I have problems opening rasters (not only
> >         yours) if I
> >         upgrade to trunk with the nightly builds repository. But this
> >         is
> >         probably caused by a mix of libraries from the standard ubuntu
> >         repository and the ubuntugis one.
> >         Cheers
> >         -- Giovanni --
> > Hugo Martins
> > LabNT - ISEGI UNL
> > Campus de Campolide
> > 1070-312 Lisboa
> > N 38°43'56.84", W 9°9'35.74"
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Hugo Martins
LabNT - ISEGI UNL
Campus de Campolide
1070-312 Lisboa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110517/9e9ac29b/attachment.html>
