[Qgis-user] Scatterplot and QGIS
Alex Mandel
tech_dev at wildintellect.com
Wed May 18 09:21:15 PDT 2011
Installation of R packages on Linux usually requires compilation steps
so make sure you have build-essential before trying to install rgdal.
sudo apt-get install build-essential
Then open R and do install.packages
If you can post more of the error message from R we can probably figure
out the problem. There is also a mailing list R-sig-geo which is a good
place to get help on stuff like this.
Enjoy,
Alex
On 05/18/2011 05:26 AM, Simone Bonzano wrote:
> Interisting but now the problem with R is the absence of the module rgdal to
> import the DEM file I need:
> Warning message:
> In install.packages("rgdal", dependencies = TRUE) :
> installation of package 'rgdal' had non-zero exit status
> I have tried many times
> 2011/5/18 <mayeul.kauffmann at free.fr>
>> Hi,
>> Have a look at the ManageR plugin (works with R).
>> The scatterplot is 2 or 3 clicks away.
>> Mayeul
>> ----- Mail Original -----
>> De: "Simone Bonzano" <simonebonzano at googlemail.com>
>> À: qgis-user at lists.osgeo.org
>> Envoyé: Mercredi 18 Mai 2011 09h40:38 GMT +01:00 Amsterdam / Berlin / Berne
>> / Rome / Stockholm / Vienne
>> Objet: [Qgis-user] Scatterplot and QGIS
>> Hi,
>> I need to plot a scatterplot about my landcape analysis on my QGIS 1.6.0,
>> with 160 sites, a Digital Elevation Model and a landscape use raster.
>> I have tried scattergram but, even with qwt5, it doesn't work: I cannot
>> select any layer. Any idea?
>> Thanks
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
