[Qgis-user] finding xy values for txt/dbf table
    Richard Duivenvoorde
    rdmailings at duif.net
    Fri May 20 06:05:02 PDT 2011
On 05/20/2011 01:32 PM, Saber wrote:
> You can digitize the points each with a unique ID similar to your
> dbf/txt/excel.
> Under Vector > Geometry Tools > Export/Add geometry.
> You can then join the 2 table either in QGIS (join under Properties > Join
> in 1.7) or in your favorite spreadsheet application (using vlookup
> function for example).
Mmm, myself I think would now load the table in postgis, add x, y and
point column and add points then (filling x and y via procedure or just
in the end).
(tried to do this with shapefiles and sqlite first: but both will not
prepare files without geometries...)
But both your and my solution are for more or less advanced users.
This use case are people who just want to open a table and a
gereferenced tiff and by selecting a record in the table and clicking in
the map the x and y is filled
Could make a plugin for it, but hoping there was another smarter
non-techie way.
Richard
