[Qgis-user] Google map in QGIS
Mayeul Kauffmann
mayeul.kauffmann at free.fr
Sat May 21 11:53:07 PDT 2011
There is a workaround, for the extent covered by the window only:
load the plugin and add one layer, epsg will be 900913.
In the file menu, chose Save as image (for instance png, there will be a
worldfile next to it).
Open your EPSG:4326. Enable on-the fly reprojection (not sure if you
need qgis 1.7 for this). Load your .png layer making sure you say this
new layer is 900913.
(I just tested it with png but I guess should work with any other
georeferenced raster).
Le samedi 21 mai 2011 à 19:02 +0100, Giovanni Manghi a écrit :
> On Sat, 2011-05-21 at 20:58 +0300, ahmet temiz wrote:
> > hello
> > I was wondering if you could give me an information about how I could get
> > google map in qgis using EPSG:4326.
> > the plugin I have uses (EPSG: 900913).
> such maps cannot be reprojected, you have to reproject the other layers
> on top of them. QGIS 1.7 will reproject also rasters.
> Cheers
> -- G --
> Qgis-user mailing list
