[Qgis-user] RE: manageR doesn't work well
burton449
burton.1 at sympatico.ca
Mon May 23 08:29:55 PDT 2011
Good day and thank you Vaclav,
I added R folder in the PATH environment variable but its not helping me with my problem. Actually, manageR can be loader correctly in QGIS but when I try to import a shapefile with the tool Import Layer from Canvas, I cannot perform analysis on this data. It seems manageR cannot load the data which is a simple polygon shapefile with an attribute table of strings and numbers. When I type ls() or objects() in manageR I got the awnser character(0) which means there is no variable loaded.
Im on Windows 7 32bit, QGIS 1.7.0 R 2.11.0 and Rpy2 2.0.3-1
Anybody have successfuly performed an analysis on a shapefile with manageR ?
Date: Mon, 23 May 2011 02:42:11 -0700
From: ml-node+6393737-1266345095-336498 at n2.nabble.com
To: burton.1 at sympatico.ca
Subject: RE: manageR doesn't work well
a very common source of problems with R and QGIS is not having the
"bin" folder of C:\Program Files\R-x.y in your PATH environment
variable. It is necessary and not created by R installation
automatically.
Vaclav
2011/5/22 Carson Farmer <[hidden email]>:
> hmm, Ok, well the only other thing I can think of is that you might
> need to install the following packages:
> install.packages(c("sp", "rgdal"))
> Carson
> On Sun, May 22, 2011 at 3:22 PM, burton449 <[hidden email]> wrote:
>> Hi Carson,
>> Sorry, my mistake, I use R 2.11.0 because in this version the executable are
>> stored in a subdirectory that rpy2 can read. Newer version of R its not
>> working with rpy2. I will try your trick to change the code in the
>> __init__.py but I dont think it would solve my problem. Actually manageR is
>> loading in QGIS but its not working properly.
>> Thank you
>> Maxime
>> ________________________________
>> Date: Sun, 22 May 2011 06:11:10 -0700
>> From: [hidden email]
>> To: [hidden email]
>> Subject: Re: manageR doesn't work well
>> Hi Maxime,
>>> Im using manageR 1.0, QGIS 1.7 and 1.6 and R 1.11.0 on Windows 7
>> Are you sure you're using R 1.11.0? That's a pretty old version! Also,
>> which version of rpy2 are you using? Furthermore, I attach an email
>> from another manageR using with a possible solution for Windows 7
>> issues:
>> I had a problem getting ManageR to run on QGIS 1.60 (OSGeoW4 install)
>> with R-2.12.1 (32 bit) on Windows 7 64 bit systems. Rpy2 complained
>> about not finding R.dll.
>> Newer versions of R place the executable files in a new subdirectory,
>> i386, below the bin directory on Windows 7 systems.
>> After searching the net for a while, I finally found the following
>> post, which seems to fix the problem:
>> http://www.mail-archive.com/rpy-list@.../msg02779.html
>> Try adding these two lines to rinterface/__init__.py
>> # Load the R dll using the explicit path
>> # First try the bin dir:
>> Rlib = os.path.join(R_HOME, 'bin', 'R.dll')
>> # Try bin/i386 subdirectory seen in R 2.12.0 ## ADDED ##
>> if not os.path.exists(Rlib): ## ADDED ##
>> Rlib = os.path.join(R_HOME, 'bin', 'i386', 'R.dll') ## ADDED ##
>> # Then the lib dir:
>> Rlib = os.path.join(R_HOME, 'lib', 'R.dll')
>> # Otherwise fail out!
>> raise RuntimeError("Unable to locate R.dll within %s" % R_HOME)
>> Hope that helps a bit,
>> Carson
>> Carson J. Q. Farmer
>> ISSP Doctoral Fellow
>> National Centre for Geocomputation
>> National University of Ireland, Maynooth,
>> http://www.carsonfarmer.com/
>> Qgis-user mailing list
>> [hidden email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1803224.n2.nabble.com/manageR-doesn-t-work-well-tp5543144p6391395.html
>> To unsubscribe from manageR doesn't work well, click here.
>> View this message in context: RE: manageR doesn't work well
>> Sent from the qgis-user mailing list archive at Nabble.com.
>> [hidden email]
> Carson J. Q. Farmer
> [hidden email]
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/manageR-doesn-t-work-well-tp5543144p6393737.html
View this message in context: http://osgeo-org.1803224.n2.nabble.com/manageR-doesn-t-work-well-tp5543144p6394931.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110523/89822aa9/attachment.html>
