[Qgis-user] printing scale of fill patterns to great
Wolf-E. Altmann
mailinglists at envitelligence.de
Tue May 24 03:13:36 PDT 2011
Am 24.05.2011 12:06, schrieb Andreas Neumann:
> Hi again,
> You can also print SVG patterns to PDF, but you have to rasterize the
> map. In the print composer in the general options use the checkbox
> "Print as Raster" and select an appropriate DPI. You will get a PDF
> with an embedded raster then. Not ideal I know.
> The bug fixing is in the works, but quite complicated, since the bug
> is in the underlying qt pdf/svg libraries.
> Andreas
> On Tue, 24 May 2011 11:47:51 +0200, Wolf-E. Altmann wrote:
>> Am 24.05.2011 11:20, schrieb Andreas Neumann:
>>> Hi Wolf,
>>> We need to know a bit more details to help you.
>>> In QGIS there are two types of patterns: SVG patterns or predefined
>>> patterns. They behave different. Which patterns are you using?
>>> Patterns are unfortunately still problematic. The predefined
>>> patterns don't print well, in fact the predefined patterns should be
>>> removed from QGIS in a future version. The SVG patterns print fine
>>> if you print to raster or to postscript. They don't print well if
>>> you export to PDF. This is a known bug in QT.
>>> As to scaling of SVG patterns: you can define the patterns in map
>>> units (in which case they scale with zooming) or in mm in which they
>>> stay in constant size, regardless of the zoom factor.
>>> Hope this helps?
>>> Andreas
>>> On Tue, 24 May 2011 11:02:28 +0200, Wolf-E. Altmann wrote:
>>>> Hello,
>>>> i am using Qgis 1.6. I want to print a map using fill patterns. On
>>>> the screen it looks ok, when i change the map scale, the scale of the
>>>> fill patterns looks all the time the same. But when i print it, the
>>>> fill pattern is very big. When i change the map scale, also the
>>>> printed pattern changes. But nevertheless using the scales 1 : 5000 or
>>>> 1 : 10000 the pattern is very big.
>>>> I tried it with various fill patterns, and the effect is the same.
>>>> Can someone help me?
>>>> Wolf
>>>> (Sorry for my English)
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Hi Andreas,
>> first I thank for the quick answer and your help.
>> Really I used the predefined patterns. But then also I tried the
>> SVG-pattern and the result was not very sharp. But I controlled it
>> only by PDF. So I will print it.
>> Wolf
Hi Andreas,
I thank you for your help.
I tried to play a little with defining the SVG-patterns i map units and
in mm. I have the feeling, that "mm" also scales with zooming. Can it be
or I am wrong?
Wolf
