[Qgis-user] editing point shape file data
maning sambale
emmanuel.sambale at gmail.com
Wed May 25 20:41:55 PDT 2011
You can use the ftools. Vector > Geometry Tools > Export/Add Geometry
Columns. This creates a new shapefile with the XCOORD and YCOORD
fields.
There should be a way to just update the existing x y values of your
layer. Just don't know how.
On Wed, May 25, 2011 at 10:44 AM, Chris Buddenhagen
<cbuddenhagen at gmail.com> wrote:
> Maning
> Ahhh ha. Got it. Duh.
> Now how to recalculate the x y values in the attribute table after moving
> the point?
> Thanks
> Chris Buddenhagen
> On Tue, May 24, 2011 at 10:19 PM, maning sambale
> <emmanuel.sambale at gmail.com> wrote:
>> You need to activate the "Move Feature" tool within the vector editing
>> tool box. Then select the point you want to move.
>> On Wed, May 25, 2011 at 10:14 AM, Chris Buddenhagen
>> > I turned on edit and selected a point from a shape file with 1000s of
>> > points, but could NOT move it to a new location using the mouse.
>> > Am I missing something?
>> > How can I move points in a shape file?
>> > Chris Buddenhagen
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
cheers,
maning
