[Qgis-user] Processing of Groundwater Databases with QGIS
G. Allegri giohappy at gmail.com
Thu May 26 14:18:37 PDT 2011
Hi Christine,
good to know you will contribute to that! I've never made R analysis
through the Qgis interface, so I can't help on that.
If you're considering kriging, as you said the two important aspects
are the specific field issues and methods (statistical reliability is
one of them, but physical and geometrical admissibility are of
preminent importance even rarely considered!), and the interface to
the tools to realize the analysis. The latter doesn't have a friendly
solution yet (IMHO), but most important would be to search ways to
integrate results assesment and analysis in the processing workflow...
Not a simple issue, but it would be a field to deepen, because many
times users "click here and there", something always comes out, but
most times it doesn't make sense :)
Let us know about your progresses.
Giovanni
PS: R has also interfaces for Postgis, shapefiles, or simply dbf
files... I don't understand what's the gain to import the datas into
Spatialite.
2011/5/26 Noli Sicad <nsicad at gmail.com>:
> Hi Christine,
> Is your current data is in database system now? Getting a subset of
> your database from your current database system (e.g. Oracle, MS SQL,
> etc.) to Spatialite database which can be easily accesses by R, Grass
> and R Geospatial for analysis. Spatialite is supported in R package a
> few weeks ago.
> Noli
> On 5/26/11, Christine Schmidt <c.schmidt at geotguide.de> wrote:
>> Hi Bob,
>> thanks for the feed back.
>> Do you capture groundwater level data in boreholes and in monitoring wells
>> with this plugin to store it in a database? Sounds interesting although I
>> wasn't searching exactly for that.
>> Want to process data of existing groundwater databases with QGIS. Processing
>> means precisely the interpolation of groundwater level data and laboratory
>> analysis data for groundwater monitoring wells.
>> I am checking what is already present in this field and what could perhaps
>> be contributed for an efficient workflow.
>> Regards,
>> Christine
>>   Von: "Bob and Deb" <bobdebm at gmail.com>
>>   Gesendet: 25.05.2011 18:31:57
>>   An: "Christine Schmidt" <c.schmidt at geotguide.de>
>>   Betreff: Re: [Qgis-user] Processsing of Groundwater Databases with QGIS
>>     Hi Christine,
>>     I've been working on a borehole data entry plugin.  We are using it to
>> record historical high groundwater for use in liquefaction zone mapping.
>>     Are you looking for this kind of use cases?
>>     Regards,
>>     Bob
>>     On May 25, 2011 9:03 AM, "Christine Schmidt" <c.schmidt at geotguide.de>
>> wrote:
>>     > Dear QGIS community,
>>     > would like to post my first question in this mailing list as follows:
>>     > a.. Does anybody know something about a project or use case of
>> processing groundwater databases with QGIS, exspecially in order to make
>> interpolations of point data (well data) ?
>>     > Got to know something similar in the context of GRASS
>> (Carrera-Hernandez, 2007). But what about QGIS in this application field ?
>>     > Thanks a lot for any feedback,
>>     > warm regards,
>>     > Christine
> Qgis-user mailing list
