[Qgis-user] Re: [Qgis-developer] Re: Mac Snow Leopard - QGIS Symbology
William Kyngesburye woklist at kyngchaos.com
Sat May 28 20:10:24 PDT 2011
Mars, can you try current git master?  I made a couple changes to the GDAL and GEOS framework detection.  Maybe not related, but it's worth a try, and there have been other changes in the past couple weeks.  I couldn't get QGIS to crash, but it's always been hard for me to verify this bug.
On May 19, 2011, at 7:28 PM, Mars Sjoden wrote:
> I have also found that changing only transparency will cause QGIS to crash also.
> Essentially I am finding that at some point, when I go to change a Layers symbol, (line weight, colour, polygon fill, point symbol) QGIS will crash.
> Sometimes it is on the first try, sometimes it takes 4-5 tries.
> While I have found various work-a-rounds that reduce the chances of QGIS crashing on a symbology change for a layer, I have not found any specific way to make it reliable, eventually QGIS crashes.
> I just tested on 1.8.0-Trunk (c7aed57)
> Simply opening Layer Properties/Style (tab) and clicking Cancel/OK/Apply will crash QGIS now.
> mars
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
