[Qgis-user] export as vector graphic
Andreas Neumann
a.neumann at carto.net
Tue May 31 01:21:20 PDT 2011
After further tests I have to say that my statement below or in my
previous email was wrong. It used to be like I explained, but now with
the current OsGeo trunk version everything is exported as raster in the
PDF. The export to SVG works better, of course, still with the
clipping/masking issue. And it seems like some stroke-widths of basic
symbols (cross, circle, etc.) is too thick.
Andreas
On Tue, 31 May 2011 07:52:55 +0200, Andreas Neumann wrote:
> Hi Alex or other Windows users who have problems with PDF export:
> Have you tried printing to a PDF (e.g. with PDFCreator) instead of
> using the export to PDF function? In my experience the results with
> printing through PDFCreator are better and I am 100% sure that when
> using the new symbology that vectors are preserved as vectors for
> lines, polygons and SVG point symbols. SVG patterns don't work when
> exportin to PDF. A bug on that is already filed and I think people
> are
> working on it.
> Andreas
> On Mon, 30 May 2011 20:21:49 -0700, Alex Mandel wrote:
>> PDF Export on Windows (Works on Linux/Mac) is broken (more info
>> https://trac.osgeo.org/qgis/ticket/3250). SVG does work but I
>> recommend
>> clipping all your data closer to the extent of the map composer
>> before
>> exporting.
>> I usually go to Inkscape as the next step from SVG or PDF and then
>> output a final PDF from there.
>> Enjoy,
>> Alex
>> On 05/30/2011 12:20 PM, Andreas Neumann wrote:
>>> Hi Christof,
>>> Vector export from the print composer to SVG or PDF should work. I
>>> recommend to use the new symbology engine. That way point symbols
>>> are
>>> kept as vectors in a PDF or SVG output. There are some problems
>>> that
>>> should be resolved in future versions, but in general it works.
>>> Also make sure you have a recent version (1.7).
>>> Andreas
>>> On 05/30/2011 07:19 PM, Christof Kluß wrote:
>>>> Hi,
>>>> is it possible to convert shapefiles into a vector format like SVG
>>>> or
>>>> PDF? Print and PDF plugin seem to convert the vector data to
>>>> raster
>>>> graphics.
>>>> If not, is there another inexpensive tool that can? So we get
>>>> scalable
>>>> PDF files?
>>>> tia
>>>> Christof
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
