[Qgis-user] Swipe functionality
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Tue Nov 1 05:58:41 PDT 2011
I'm not convinced this will do what I want, but am willing to try it. I've
found and downloaded the relevant zip - but how do I install it?
The documentation I find says to use the "Fetch plugins" functionality for
installing, but that requires an internet connection which the QGIS
machine doesn't have. Are there manual install instructions?
Thanks,
Jonathan
From:   "Saber Razmjooei" <razmjooeis at faunalia.co.uk>
To:     jonathanmoules at warwickshire.gov.uk
Cc:     qgis-user at lists.osgeo.org
Date:   01/11/2011 11:40
Subject:        Re: [Qgis-user] Swipe functionality
Check for Raster Transparency in the plugin repo from GIS-Lab
Cheers
Saber
> Hi list,
>         Does QGIS (or a plugin) have "swipe" functionality, where you
can
> smoothly swipe between a raster and whatever is underneath it? I found a
> 18 month old forum post asking (
> http://forum.qgis.org/viewtopic.php?f=2&t=6563), but no-one answered it.
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it,
or
> disclose it to anyone else. If you have received this transmission in
> error please notify the sender immediately. All email traffic sent to or
> from us,  including without limitation all GCSX traffic, may be subject
to
> recording and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111101/09cbdccc/attachment.html>
