[Qgis-user] Scale seems strange in
    James Stott
    James.Stott at npaconsult.co.uk
    Wed Nov  2 07:02:54 PDT 2011
Could this just be a windows thing then? I tried an older version of qgis-dev (1.8.0-78) on a different windows machine in the office and there are no problems. Metres should be the default setting for 27700 shouldn't it not degrees?
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
http://www.npaconsult.co.uk/
-----Original Message-----
From: Saber Razmjooei [mailto:razmjooeis at faunalia.co.uk]
Sent: 02 November 2011 10:48
To: James Stott
Cc: qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] Scale seems strange in
James
I am using QGIS-Trunk under ubuntu 10.04. The canvas projection is set
to 27700 and Layer unit to metre.
The scale seems to be fine and not affected by panning.
Cheers
Saber
On Wed, 2011-11-02 at 10:43 +0000, James Stott wrote:
> An update:
> This is also happening on a colleague’s machine. I have reverted back
> to the previous OSGeo4W nightly and that doesn’t fix the problem.
> Uninstalling and reinstalling doesn’t work.
> In 1.7, if I open up this certain dataset of viewpoint locations, it
> opens with a scale of 1:53478. In 1.8 if I load the dataset it opens
> at a scale of 1:5325654358. If I use the pan tool and just click on
> the map the scale changes to 1:631588609, then 1:2918610855, then
> 1:2934133484 and so on. Distance measures seem unaffected. It seems to
> be being caused by the units of the project being set to degrees. I
> have saved a project and the units are set to degrees. If I open an
> old project up it opens at the correct scale. In my old project files
> it is set to metres. (see examples below). It seems I have to make
> sure Enable on the fly projection is unticked in the project
> properties, and then manually set the Layer units to metres in the
> general tab.
> I was also having problems a while ago with exporting to MapInfo but I
> have just tried this and it works. See links below for details. It is
> including the 79 not the 104 now.
> http://gis.stackexchange.com/questions/14350/qgis-and-mapinfo-projections-epsg-27700-british-national-grid
> http://hub.qgis.org/issues/4271
> New project:
> <mapcanvas>
>         <units>degrees</units>
>         <extent>
>             <xmin>384571.226869</xmin>
>             <ymin>78401.536498</ymin>
>             <xmax>408875.829430</xmax>
>             <ymax>92579.221325</ymax>
>         </extent>
>         <projections>0</projections>
>         <destinationsrs>
>             <spatialrefsys>
>                 <proj4>+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717
> +x_0=400000 +y_0=-100000 +ellps=airy
> +towgs84=446.448,-125.157,542.06,0.15,0.247,0.842,-20.489 +units=m
> +no_defs</proj4>
>                 <srsid>2437</srsid>
>                 <srid>27700</srid>
>                 <authid>EPSG:27700</authid>
>                 <description>OSGB 1936 / British National
> Grid</description>
>                 <projectionacronym>tmerc</projectionacronym>
>                 <ellipsoidacronym>airy</ellipsoidacronym>
>                 <geographicflag>false</geographicflag>
>             </spatialrefsys>
>         </destinationsrs>
>     </mapcanvas>
> Old project:
> <mapcanvas>
>         <units>meters</units>
>         <extent>
>             <xmin>400790.090563</xmin>
>             <ymin>86512.592259</ymin>
>             <xmax>401731.465923</xmax>
>             <ymax>87217.568425</ymax>
>         </extent>
>         <destinationsrs>
>             <spatialrefsys>
> +no_defs</proj4>
>                 <srsid>2437</srsid>
>                 <srid>27700</srid>
> Grid</description>
>             </spatialrefsys>
>         </destinationsrs>
>     </mapcanvas>
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of James Stott
> Sent: 01 November 2011 09:15
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Scale seems strange in
> Hi all,
> I am having problems with scales on v1.8 (7297b23) from OSGeo4W.
> If I open an existing project everything is fine.
> If I open data in a fresh QGIS session it is reporting strange scales.
> It doesn’t matter what source the data is. For example, I open a
> dataset and it reports 1:784735546. It seems to report correct
> distances. If I pan the scale changes.
> I am using EPSG 27700 (British National Grid).
> Does anyone have any idea what can be causing this?
> James
> Nicholas Pearson Associates, LogoNicholas Pearson Associates, Latest
> News
> Information and Registered Address
> This Electronic Transmission is intended only for the attention of the
> addressee. It may contain privileged and confidential information. If
> you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44
> (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> Qgis-user mailing list
http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
http://www.npaconsult.co.uk/terms.asp
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
