[Qgis-user] Re: Qgis-user Digest, Vol 69, Issue 21
Kurt Springs
ferret_bard at mac.com
Sat Nov 5 18:24:26 PDT 2011
I haven't gotten that far. How did you load the pyspatialite python plug in? Whe I try to run Qspatialite it tells me it can't find pyspatialite. I tried to load it via the easy_install method, but it won't install.
Kurt
On Nov 6, 2011, at 12:00 PM, Mars Sjoden wrote:
> Has anyone else found the following issue?
> 1.
> Using Mac OS X QGIS 1.7.1 - William Kyng.‚s Frameworks (Also occurs on
> QGIS 1.8 Kyng.‚s)
> 1.
> Uploading a Medium sized shapefile to QspatiaLite
> 1.
> QGIS Layer
> 1.
> Use VirtualShape Import (*check ON*)
> * BUG CRASH does not occur when [Use VirtualShape Import] check OFF
> Reports and SHP:
> Upload Tables QspatiaLite - Using VirtualShape Import -
> https://docs.google.com/open?id=0B63BcSDiEI_7YzdkM2JkMTctMWRlMS00OWI2LWEwZDgtNDhiYmJhMTg5Yjg4
> Publicly available Shapefile from:
> http://geobc.gov.bc.ca/ DOWNLOAD -> Free Data -> [Guest Users Enter Here]
> category:
> *Configururable Products*
> *Land and Natural Resources Information > Forests, Grasslands and Wetlands*
> VRI - Forest Vegetation Composite Polygons and Rank 1
> Mapsheet: 093L047
> Mars
