[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Noli Sicad
nsicad at gmail.com
Wed Nov 9 02:26:04 PST 2011
OK. I saw it. Thanks.
I am now in Mac OS X.
My laptop is triple boot :-).
I toggled the Pencil icon - edit, yet I could not make to change or
use the defaullt rectangle to draw.
How do you use this plugin?
Noli
On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
> Works for me under Ubuntu 10.04.
> The icon should be towards the end of your Digitizing toolbar. You need
> to click on it and hold to see other shapes.
> Cheers
> Saber
> On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
>> This plugin seems not to work with Ubuntu 10.04.
>> Yes, I checked in QGIS manage plugin. It installed by I could see the
>> icon and the menu entry in QGIS.
>> I created a new shapefile and I toogle to edit. No icons showing in
>> the toolbar that resembled or look like this.
>> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
>> Any instruction how to make it work in Ubuntu?
>> Thanks.
>> Noli
>> On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
>> > Hello,
>> > i would like to introduce you the new Rectangles ovals digitizing
>> > plugin.
>> > This plugin is available in QGIS Contributed Repository and after
>> > installing creates three new objects in Digitizing toolbar: one
>> > multifunction button with digitizing tools, one button for rotation of
>> > rectangles or ovals and spinbox for changing of number of segments for
>> > ovals. There are 6 digitizing tools: "Rectangle by extent", "Rectangle
>> > from center", "Square from center", "Circle from center", "Ellipse by
>> > extent", "Ellipse from center". Plugin is active only when you are
>> > editing polygon layers. Tools, which have "from centre" in the name are
>> > able of snapping (after defining in Snapping Options tab of Settings)
>> > of the virtual center of feature.
>> > "Rotation tool" is functional after selection of (exactly) one
>> > rectangle or oval.
>> > After digitizing of feature, there is Feature form with possibility of
>> > changing default attribute values. You can deactivate this in Settings
>> > -> Options -> Digitizing tab -> "Suppress attributes pop-up windows
>> > after each created feature". Option "Reuse last entered attribute
>> > values" is not supported.
>> > I hope you will find this tools useful.
>> > Regards
>> > Pavol
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
