[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Noli Sicad
nsicad at gmail.com
Wed Nov 9 02:41:50 PST 2011
It was inactive. Nothing happened if you drag the rectangle.
Now, I uninstalled and installed it again.
Now, the icon inactive is gone.
It is totally not working in Mac OS X QGIS 1.7.1.
I will checked Ubuntu in few minutes. After I download Qt 4.7.4. It is
quite big download 1.3G for Mac OS X.
http://labs.qt.nokia.com/2011/11/08/qt-4-7-4-release-bundle-for-symbian-news/
Thanks.
On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
> Select a shape from the toolbar, in the canvas: click and drag.
> Cheers
> Saber
> On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
>> OK. I saw it. Thanks.
>> I am now in Mac OS X.
>> My laptop is triple boot :-).
>> I toggled the Pencil icon - edit, yet I could not make to change or
>> use the defaullt rectangle to draw.
>> How do you use this plugin?
>> Noli
>> > Works for me under Ubuntu 10.04.
>> > The icon should be towards the end of your Digitizing toolbar. You need
>> > to click on it and hold to see other shapes.
>> > Cheers
>> > Saber
>> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
>> >> This plugin seems not to work with Ubuntu 10.04.
>> >> Yes, I checked in QGIS manage plugin. It installed by I could see the
>> >> icon and the menu entry in QGIS.
>> >> I created a new shapefile and I toogle to edit. No icons showing in
>> >> the toolbar that resembled or look like this.
>> >> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
>> >> Any instruction how to make it work in Ubuntu?
>> >> Thanks.
>> >> Noli
>> >> On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
>> >> > Hello,
>> >> > i would like to introduce you the new Rectangles ovals digitizing
>> >> > plugin.
>> >> > This plugin is available in QGIS Contributed Repository and after
>> >> > installing creates three new objects in Digitizing toolbar: one
>> >> > multifunction button with digitizing tools, one button for rotation
>> >> > of
>> >> > rectangles or ovals and spinbox for changing of number of segments
>> >> > for
>> >> > ovals. There are 6 digitizing tools: "Rectangle by extent",
>> >> > "Rectangle
>> >> > from center", "Square from center", "Circle from center", "Ellipse by
>> >> > extent", "Ellipse from center". Plugin is active only when you are
>> >> > editing polygon layers. Tools, which have "from centre" in the name
>> >> > are
>> >> > able of snapping (after defining in Snapping Options tab of Settings)
>> >> > of the virtual center of feature.
>> >> > "Rotation tool" is functional after selection of (exactly) one
>> >> > rectangle or oval.
>> >> > After digitizing of feature, there is Feature form with possibility
>> >> > of
>> >> > changing default attribute values. You can deactivate this in
>> >> > Settings
>> >> > -> Options -> Digitizing tab -> "Suppress attributes pop-up windows
>> >> > after each created feature". Option "Reuse last entered attribute
>> >> > values" is not supported.
>> >> > I hope you will find this tools useful.
>> >> > Regards
>> >> > Pavol
>> >> > _______________________________________________
>> >> > Qgis-user mailing list
>> >> > Qgis-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
