[Qgis-user] Georeference Plugin - UI issue?
Mars Sjoden
marsofearth at gmail.com
Fri Nov 11 11:42:28 PST 2011
I concur that the Georeferencing is not working that well in OS X.
When you select a reference point in the Raster it pops up a Enter map
coordinates window
When you ask to select from map canvas the Georeferencer window hides
Once you select the map canvas co-ordinate, the Georeferencer window
unhides BUT
The Enter map coordinates window becomes buried behind every QGIS Window as
last priority.
The Enter map coordinates window needs to be "Always On Top"
Tested on 1.7.1
mars
- Hide quoted text -
On Wed, Nov 9, 2011 at 7:48 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Good to know that QGIS in Mac OS X is getting stable.
> However, there are 2 things that it is not working in QGIS Mac OS X, right
> now.
> 1. Georeferencing plugin (C++ plugin).
> 2. Rectangle, Oval and Diamonds (Digitizing) python plugin.
> These 2 plugins are working properly properly in Ubuntu 10.04.
> (I have 3 triple laptop (Window 7, Mac OS X (10.6.4) and Ubuntu
> 10.04), so I can switch back and forth from Mac OS X and Ubuntu at the
> moment. Windows 7 is dormant at moment).
> I prefer to use Mac OS X with QGIS since I could run several version
> of QGIS by just renaming QGIS and installed another version).
> Thanks.
> Noli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111111/768efca6/attachment.html>
