[Qgis-user] Re: Snap points to nearest line
magerlin MAP at ramboll.dk
Tue Nov 15 02:52:02 PST 2011
Cameron Munro wrote:
> Hi,
> I have two layers - points and lines. I'd like to snap the points to the
> nearest line and take the attributes of that line. Is this possible within
> QGIS?
> Thanks,
> Cameron.
Hi Cameron
Two suggestions, but not an excact solution:
You can use the mmqgis plugin and select "Hub Distance". With this you can
transfer an attribute (or an ID and then use a join afterwards) to a
pointlayer from the nearest line in a linelayer.
But be aware that "nearest" line will be based only on a "centre point" for
the line and if your lines are very curved or of varying lengths you may not
get the expected result.
You might use the "Vector-Geometry Tools-Extract Nodes" to convert your line
layer to a point layer and use this point layer as the Hublayer instead of
the line layer.
Anybody knows an excact method?
Regards Morten
(Qgis 1.7.1 and Win 7)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Snap-points-to-nearest-line-tp6994907p6995832.html
Sent from the qgis-user mailing list archive at Nabble.com.
