[Qgis-user] Error when launching QGIS
Giuseppe Sucameli sucameli at faunalia.it
Wed Nov 16 03:18:48 PST 2011
Hi António,
2011/11/16 António Rocha <toyze.rocha at gmail.com>:
> I tried to reinstall it and I got this message:
> The plugin depends on some components missing on your system. You need to
> install the following Python module in order to enable it: osgeo
> [python-gdal]
> But I do have this in my machine (in python if I do import osgeo I have this
> package)
> Any suggestion?
do you have more python versions installed on board?
If you try "import osgeo" from QGis plugins->python console do you
have the same result?
Regards.
> Antonio
> 2011/11/15 Giuseppe Sucameli <sucameli at faunalia.it>
>> Hi António,
>> what's the GdalTools plugin installed version?
>> Can you install the latest GdalTools version from the plugins
>> installer (you have to enable experimental plugins) and then
>> try again?
>> Regards.
>> 2011/11/15 António Rocha <toyze.rocha at gmail.com>:
>> > Sorry
>> > CentOS
>> > QGIS1.6.0
>> > 2011/11/15 Giovanni Manghi <giovanni.manghi at gmail.com>
>> >> Olá Antonio,
>> >> On Tue, 2011-11-15 at 18:01 +0000, António Rocha wrote:
>> >> > Greetings
>> >> > When I launch QGIS I get the following error:
>> >> > Loaded : __error__ (package: GdalTools)
>> >> > But I have GDAL in my system (1.8.0).
>> >> > And a Panel with a Python error  that starts with:
>> >> > "Couldn't load plugin GdalTools due an error whern calling its
>> >> > classFactory() method
>> >> What Operating system? installer? qgis version?
>> >> cheers
>> >> -- Giovanni --
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giuseppe Sucameli
Giuseppe Sucameli
