[Qgis-user] PyQGIS can't load - QGIS 1.7 loading error obtained after upgrade linux/ubuntu from distribution 11.04 to 11.10
Florent Beck
beckflorent at gmail.com
Thu Nov 17 10:31:17 PST 2011
Merci Yves !
It was the good thing to do ! Checking this I found out that I wasn't
using the good packages sources.
I had to add the ubuntugis unstable ppa
(https://launchpad.net/%7Eubuntugis/+archive/ubuntugis-unstable) to my
source list and delete old qgis packages sources that remained there.
Now it's working.
thanks again !
Florent
2011/11/15, Yves Jacolin <yjacolin at free.fr>:
> Bonjour Florent,
> check that all package have been uptaded correctly, specially the one named
> python-qgis. Check also that all previous package have been removed. You can
> also try ldconfig command on root to update path db to your lib.
> Y.
> Le samedi 12 novembre 2011 19:22:58, Florent Beck a écrit :
>> Hello,
>> I am using QGIS for a while and have being more or less lucky with bug
>> issues, but this time I don't understand alone how to fix it.
>> I was using QGIS 1.7 since its release under Linux/Ubuntu 11.04, now
>> that I have just upgraded to the new distribution of Ubuntu (11.10), I
>> get the following error message while QGIS loads, and after it has
>> finished loading, I can't access the plugin installer (only plugin
>> manager and already installed plugins).
>> You may help me if you would know in which direction I could look to
>> handle
>> it.
>> Thanks you
>> Florent Beck
>> Here the error message: (as I got it in french I'll translate french
>> parts into english within brackets after each line)
>> Error message : >>>
>> Impossible de charger PyQGIS. [Can't load PyQGIS.]
>> Le support python va être désactivé. [Python support will be desabled
>> (or deactivated ?).]
>> Traceback (most recent call last):
>> File "", line 1, in
>> RuntimeError: the PyQt4.QtCore module is version 1 but the qgis.core
>> module requires version -1
>> Version de Python : [Python's version :]
>> 2.7.2+ (default, Oct 4 2011, 20:29:37)
>> [GCC 4.6.1]
>> Version de QGIS : [QGIS's version :]
>> 1.7.1-Wroclaw 'Wroclaw', exported
>> Chemin vers Python : [Path to Python :]
>> ['/usr/share/qgis/python',
>> '/home/forest/.qgis/python',
>> '/home/forest/.qgis/python/plugins',
>> '/usr/share/qgis/python/plugins',
>> '/usr/lib/python2.7',
>> '/usr/lib/python2.7/plat-linux2',
>> '/usr/lib/python2.7/lib-tk',
>> '/usr/lib/python2.7/lib-old',
>> '/usr/lib/python2.7/lib-dynload',
>> '/usr/local/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages/PIL',
>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.7',
>> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
>> <<< END of the error message.
>> Thanks in advance for each kind of help.
>> Florent
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Yves Jacolin
> http://yjacolin.gloobe.org
