[Qgis-user] Can't load PostGIS views
Noli Sicad nsicad at gmail.com
Fri Nov 18 15:53:21 PST 2011
Hi Mathieu,
Tim has a solution to bring a view into QGIS.
Here's the link.
http://linfiniti.com/2011/11/adding-a-counter-to-postgresql-query-results/
Noli
On 11/19/11, Mathieu Ouellette <ouellette.mathieu at gmail.com> wrote:
> Hi,
> I have a PostGIS database and I'm trying to load some views in QGIS 1.7 but
> it doesn't work. The error message title is in French but basically it says
> that QGIS can't find an appropriate primary key. The message regarding the
> column which would normally acts as a primary key is in French again but it
> says that is not suitable because its type is int4 and it doesn't have
> constraints.
> However, this column has a primary key constraint in the base table, has a
> unique constraint and is set to NOT NULL... I also created a test view in
> which the select query is identical to the base table (no joins, no alias,
> ...) and the same error happens (while the base table is loading
> perfectly). In order to push further, I made a SELECT DISTINCT query on my
> id column and a SELECT COUNT(DISTINCT my_id_column) on both the base table
> and the test view and I got the same numbers so the values of this column
> are really unique. I also loaded my views in uDig and I got no problem.
> Does anybody have any idea on what could be causing this problem?
> Thanks a lot,
> Mathieu
