[Qgis-user] Joining tables and spatial data
Andreas Neumann
a.neumann at carto.net
Thu Nov 24 08:39:56 PST 2011
asfaik - one to many is currently not possible. It would also result in
a duplication of geometries, if you join from one geometry to multiple
records ... probably not what you want.
If you want to join and aggregate, you can do so in a real database,
such as PostgreSQL.
Andreas
On Thu, 24 Nov 2011 16:14:41 -0000, James Stott wrote:
> If you have managed to do this could you let me know how?
> I can only get it to do a one to one join, not a one to many join.
> BSc (Hons) MSc | Senior Professional
> | 30 Brock Street | Bath | BA1 2LN
> 01225 445548 | -
> FROM: Nick Turner [mailto:ngturner at gmail.com]
> SENT: 23 November 2011 19:10
> TO: James Stott
> CC: qgis-user at lists.osgeo.org
> SUBJECT: Re: [Qgis-user] Joining tables and spatial data
> I have overcome what I think to be a similar problem by using the
> second method you mention, then sorting the table by any column. All
> entries then show on my system.
> Nick Turner
> On Wed, Nov 23, 2011 at 11:24 AM, James Stott wrote:
> I would like to join an attribute table (.csv) to some spatial data
> (shapefile). I have added both the shapefile and the CSV into QGIS.
> Now I can join them using the Join tab on the csv file layer
> properties tab, but this doesn't give me any spatial information from
> the shapefile. What I would like to be able to do is see the polygons
> that have been joined from the shapefile. Is this possible?
> I have also joined the csv to the shapefile but this does not give me
> multiple records. The CSV has multiple records and when I join in
> this
> way then I only get one record back from the shapefile. Is it
> possible
> to do one to many using the join tab?
> Using qgis-dev from OSGeo4W.
> James
> JAMES STOTT BSc (Hons) MSc | Senior Professional
> NICHOLAS PEARSON ASSOCIATES | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> WWW.NPACONSULT.CO.UK [2]
> [3] [4]
> Information and Registered Address [5]
> This Electronic Transmission is intended only for the attention of
> the
> addressee. It may contain privileged and confidential information. If
> you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel:
> +44
> (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> http://www.npaconsult.co.uk [6]
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org [7]
> http://lists.osgeo.org/mailman/listinfo/qgis-user [8]
> Links:
> [1] mailto:James.Stott at npaconsult.co.uk
> [2] http://www.npaconsult.co.uk/
> [3] http://www.npaconsult.co.uk/
> [4] http://www.npaconsult.co.uk/about-news.asp
> [5] http://www.npaconsult.co.uk/terms.asp
> [6] http://www.npaconsult.co.uk/
> [7] mailto:Qgis-user at lists.osgeo.org
> [8] http://lists.osgeo.org/mailman/listinfo/qgis-user
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
