[Qgis-user] adding HDF-EOS (.hdf) rasters?
Etienne Tourigny
etourigny.dev at gmail.com
Mon Nov 28 03:29:18 PST 2011
I have the same issue with netcdf files with multiple datasets. (using
QGis and GDAL trunk).
Could this be related to the GDAL raster provider?
regards, Etienne
On Sun, Nov 27, 2011 at 11:10 AM, Ivan Shmakov <oneingray at gmail.com> wrote:
> I vaguely recall that (in 1.7.0?) when an HDF-EOS (.hdf) file
> was selected while adding a raster, QGIS was to show a dialog to
> select the particular HDF-EOS field (variable) to be added.
> Now, in 1.7.1, QGIS simply states that it can't load the file
> selected. (Tried on many, including, for instance, [1].)
> Is it a regression, or something else?
> The work-around that seems to work for me is to use
> gdal_translate(1) to prepare the respective GDAL Virtual Raster
> (.vrt), and load the latter instead.
> TIA.
> [1] ftp://e4ftl01.cr.usgs.gov/MODIS_Dailies_B/MOLA/MYD09CMG.005/2011.11.14/MYD09CMG.A2011318.005.2011320043437.hdf
> FSF associate member #7257
> Qgis-user mailing list
