[Qgis-user] Scale bar on degrees with project CRS on ED50 UTM31
Gerardo Jimenez
gejst5 at hotmail.com
Tue Nov 29 10:39:23 PST 2011
Works on windows too!!! Thanks for the advice!
Gerardo Jiménez Delgado
Instituto de Investigaciones Antropológicas
Universidad Nacional Autónoma de México
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
> Date: Tue, 29 Nov 2011 15:33:17 +0100
> Subject: Re: [Qgis-user] Scale bar on degrees with project CRS on ED50 UTM31
> From: alobolistas at gmail.com
> To: dassau at gbd-consult.de
> CC: qgis-user at lists.osgeo.org
> It works here (on ubuntu). It seems the only bug is just that the
> units are not automatically set to
> the units of the CRS.
> Agus
> 2011/11/29 Otto Dassau <dassau at gbd-consult.de>:
> > Hi,
> > you could try to set Layer Units in menu Settings -> Project Properties ->
> > General tab to Meters. Usually this should be done automatically, based on
> > the units of the CRS you select. Maybe that doesn't work?
> > Regards
> > Otto
> > Am Tue, 29 Nov 2011 09:13:48 -0500
> > schrieb Gerardo Jimenez <gejst5 at hotmail.com>:
> >> The same happened to me in a win stadnallone install on xp, vista and 7
> >> and ubuntu. Main thing, scale bar seem not to work well on 1.72.
> >> Nevertheless, I check if I coul use the measure tool and make a
> >> reprojection of som layers in UTM wgs84 14N and both procedures work ok.
> >> Then, Qgis recognizes my CRS, but the scale bar does not work. I get
> >> around this by getting rid off the scale bar. Not a total solution but it
> >> works. and the only thing is to get use to work without the scale bar in
> >> the data frame.
> >> Hope it helps
> >> Coyoacan 04510
> >> Mexico City
> >> Mexico
> >> 56 22 95 16
> >> > Date: Tue, 29 Nov 2011 07:51:27 +0100
> >> > To: qgis-user at lists.osgeo.org
> >> > Subject: [Qgis-user] Scale bar on degrees with project CRS on ED50 UTM31
> >> > Using 1.7.2, the scale bar is on degrees while project and
> >> > layer CRS are projected. See screenshot here:
> >> > https://sites.google.com/site/filestemp2/home/scalebar.jpeg?attredirects=0
> >> > Agus
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111129/8a93e2c3/attachment.html>
