[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2 from ubuntu binaries
Agustin Lobo
alobolistas at gmail.com
Wed Nov 30 21:27:07 PST 2011
Just clarifying I was updating through the update manager of ubuntu,
not through the deb files.
Agus
2011/12/1 Etienne Tourigny <etourigny.dev at gmail.com>:
> I think I misunderstood the problem, the ubuntugis-unstable repos only
> allows 1 version of qgis installed at a time.
> If you need to uninstall qgis-1.7.0 before upgraging to 1.7.2, then
> there surely must be a problem with the upgrade process in the .deb?
> On Wed, Nov 30, 2011 at 5:21 PM, David J. Bakeman <dbakeman at comcast.net> wrote:
>> Etienne Tourigny wrote:
>>> shouldn't qgis be packaged in such a way to avoid multiple (minor)
>>> versions of QGIS?
>>> i.e. change the package names to 1.7 instead of 1.7.0 / 1.7.1 / 1.7.2 ?
>>> There really is no need to have the old packages around, especially
>>> with this issue.
>> I respectfully disagree. It's not that the old packages need to be around
>> it's that they are
>> out there already.
>> People have them some people either can't or won't be
>> able to upgrade
>> them and when those people have questions it's important that the developers
>> and others
>> know exactly what version of the software is being discussed.
>>> Regards,
>>> Etienne
>>> On Tue, Nov 29, 2011 at 8:09 AM, Noli Sicad<nsicad at gmail.com> wrote:
>>>>> reproduced the problem by installing on another machine with ubuntu
>>>>> 10.04 . Running qgis from the command line I get:
>>>>> alobo at delia:~$ qgis
>>>>> Warning: loading of qgis translation failed
>>>>> [/usr/share/qgis/i18n//qgis_en_US]
>>>>> Warning: loading of qt translation failed
>>>>> [/usr/share/qt4/translations/qt_en_US]
>>>>> Warning: Couldn't load Python support library: Cannot load library
>>>>> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
>>>>> file: No such file or directory)
>>>> In ubuntu 10.04 Lucid, you have to install
>>>> - python-qgis 1.7.2~Lucid1
>>>> - python-qgis-common 1.7.2-1~Lucid1
>>>> If you upgrade from other version (e.g. 1.7.0), you have to remove
>>>> first the old version then install 1.7.2.
>>>> Noli
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
